TP-Link Archer VR2800 and PlusNet
- My Router
- TP-Link Archer VR2800 and PlusNet
27-07-2017 2:28 PM
Just some feedback that connection to PlusNet is pretty automatic for this top of the range router from TP-Link - you just select PlusNet from the drop down box and that, together with your username and pasword, is all you need!
Re: TP-Link Archer VR2800 and PlusNet
27-07-2017 3:09 PM
01-08-2017 3:19 PM
... and would you recommend it?
on
01-08-2017
3:58 PM
- last edited on
01-08-2017
4:07 PM
by
Mav
Yes, it's a pretty potent package if you need that sort of throughput as clearly it's not cheap.
Technical support is a bit of an issue; although there are UK phone lines, I got stuck with people based in China, communicating via chat, which wasn't very good.
Moderator's note by Mike (Mav): Full quote of preceding post removed as per Forum rules.
01-08-2017 4:34 PM
Thanks for the reply - it's on my wishlist!
- My Router
