TP Link Archer D7 settings for Plusnet ADSL
- My Router
- TP Link Archer D7 settings for Plusnet ADSL
03-07-2018 7:25 AM - edited 03-07-2018 4:33 PM
Hi all, I just cant get this router to connect. Ive been through the quick settings guide and have selected everything that is suggested, but just cant get it to connect. Can anyone talk me through what to do?
Re: TP Link Archer D7 settings for Plusnet ADSL
03-07-2018 8:52 AM
Have you had the activation confirmation e mail from PN, otherwise
pointless trying to connect.
Check here too;
https://www.plus.net/help/broadband/broadband-connection-settings/
03-07-2018 10:10 AM - edited 03-07-2018 10:12 AM
Assuming you have a router supplied by Plusnet then connect that and confirm that you have a broadband connection. Assuming that is OK then go through the process in Chapter 4.1/ 4.2 of the manual https://static.tp-link.com/res/down/doc/Archer_D7(EU)_V1_UG.pdf. If you need to input the details manually you will find them here https://www.plus.net/help/broadband/broadband-connection-settings/
03-07-2018 11:05 AM
Thank you very much. Broadband works on the Plusnet router. I have tried to follow the guide listed on the router settings page. Ive reset the router a couple of times too, but still cant get it to see the internet. Ill give it another go shortly and will get back to you. Stumped, Im afraid!
03-07-2018 11:24 AM
Thank you. Any idea how I move this post to My router?
03-07-2018 12:13 PM
03-07-2018 12:16 PM - edited 03-07-2018 12:18 PM
How far do you get with setting up the D7? The sort of error people make is to use the wrong password - you need to use the one that you use to log into the Plusnet Member Centre, NOT the router admin or wireless one.
03-07-2018 12:35 PM
03-07-2018 3:45 PM
Can you log into the Plusnet Member Centre with the username and password? Have you set the router to PPPoA (routers tend to default to PPPoE) VCI/ VPI to 38/0 ant multiplexing to VC Based?
03-07-2018 4:19 PM
Yes all set as below but with username and password fcompleted
ATM Configuration
VPI(0-255):0
VCI(32-65535):38
Encapsulation Mode:VC-Mux
ATM QoS Type:UBR
PCR:0 frames/s
SCR:0 frames/s
MBS:0 frames/s
WAN Service Setup
Connection Type:PPPoA
PPP Username:
PPP Password:
Confirm password:
Connection Mode: Always on
Connect on demand
Connect manually
Max Idle Time: minutes (0 meaning connection remains active at all times)
Authentication Type:
Default Gateway:
MTU(Bytes😞 (1480 as default, do not change unless necessary)
Enable SPI Firewall:
Enable IGMP Proxy:
Use IP address specified by ISP:
Echo request interval: (0-120 seconds, 0 meaning no request)
Set DNS server manually:
04-07-2018 9:04 AM
Here is a better screen shot of the settings
04-07-2018 9:34 AM - edited 04-07-2018 9:44 AM
I’m clutching at straws now but it doesn’t look as though Save had been set.
04-07-2018 9:45 AM - edited 04-07-2018 10:08 AM
sorry, pointless post
04-07-2018 12:16 PM
Nothing leaps out from the screenshot, although the red text at the bottom is a bit odd ('Connection will be deleted...').
Also, you might want to change your WiFi keys now 😉
04-07-2018 12:31 PM
Moderator's note:
Topic moved to 'My Router'
- My Router
