TP Link AC2800 won’t connect
iancolcomb
I recently moved house, and while I was on fibre extra, I didn’t have the BT master socket, so was sent the hub 1 which connected through the phone line.
I decided to replace the hub with a TP Link AC2800, despite putting in the correct credentials and settings (tried both VDSL and ADSL) it refuses to connect to the ISP and the console doesn’t have any logs or help with why it’s failing. Any ideas?
10 REPLIES 10
iancolcomb
Re: TP Link AC2800 won’t connect
To add to this, it finally connected and worked, yet then drops and loses connection. I had occasions when Facebook wouldn’t refresh I put down to the plus.net hub hence buying a new top spec router, but could it be my connection isn’t stable and keeps dropping?
EmilyD
Fixes: 117
Hi @iancolcomb,
I'm sorry to hear that you've been experiencing problems with your connection, both when connected with your TP Link router and with your Plusnet router.
I've tested your line but the test hasn't picked up the cause of this issue from here:
GEA Test Detail
Circuit ID NA Service ID BBEUXXXXXXXX
Test Outcome Pass
Main Fault Location OK
Sync Status In Sync
Downstream Speed 76.5 Mbps
Upstream Speed 20.0 Mbps
Appointment Required N
Fault Report Advised N
NTE Power Status PowerOn
Voice Line Test Result Pass
Bridge Tap Not Detected
Cross Talk Not Detected
Estimated Line Length In Metres 409.8
Upstream Rate Assessment Very Good
Technology VDSL
Profile Name 0.128M-80M Downstream, Interleaving Low - 0.128M-20M Upstream, Error Protection Off
Time Stamp 2018-10-03T21:45:00
Parameters MIN MAX AVG
Down Stream Line Rate 64.2 Mbps 79.9 Mbps 75.5 Mbps
Up Stream Line Rate 19.9 Mbps 19.9 Mbps 19.9 Mbps
Up Time 0.0 Sec 900.0 Sec 897.2 Sec
Retrains 0.0 160.0 0.3
Current and Last 15 Minute Bin Performance
Parameters Last Traffic Count(Upto 15 mins) Current Traffic Count(Upto 15 mins)
Start Time Stamp 2018-10-17T11:08:31Z 2018-10-17T11:23:31Z
Ingress Code Violation 0 0
Egress Code Violation 0 0
Errored Seconds 0 0
Severely Errored Seconds 0 0
Unavailable Seconds 0 0
Does this issue solely affect wireless connections or does it affect wired connections too?
Please can you run through our troubleshooting guides here and let us know how you get on. If the issue persists once you've done the troubleshooting checks, please report it  here and let us know when you've completed it.
 Emily D
iancolcomb
Hi
I have plugged the old plusnet hub in to have internet.
Issues effects both wireless and wired connections as it’s the router authenticating the broadband connection that’s the issue.
I have tried the troubleshooting guide, but I will connect the TP link router and try them again and report back
MasterOfReality
Fixes: 57
@iancolcomb - thanks for the update.
Just to confirm, when you use the PN router you are able to authenticate and establish a connection to the internet?
Let us know how it goes with the TP.
Thanks,
MoR
iancolcomb
Yes, both routers authenticate and connect, the TP router then loses connection after approximately 5-10 minutes. The PN router does have “dead” moments where videos stop streaming/Facebook won’t refresh, but this doesn’t register as a disconnect (from what I can see) but then all is fine a few minutes later, which I don’t have with the TP
OskarPapa
Fixes: 65
Hi @iancolcomb ,
Thanks for your post.
I've run testing on your line and we aren't detecting any sort of issue and the stability seems to be within the acceptable range as the below graph shows:
As we're showing no disconnections since Tuesday, has the issue now resolved itself?
iancolcomb
Unfortunately I only managed to connect the TP router today, however it has been connected for over an hour so appears to be working, I will keep an eye on it but believe it may be resolved thank you.
Manickbarry42
Hi I just got one of these AC2800 and mine won’t connect at all, I have tried vdsl and adsl but neither work.
Can someone help me out here.
MasterOfReality
Fixes: 57
Hi @Manickbarry42
We have little diagnostic help available when it comes to 3rd party hardware I'm afraid.
To configure a 3rd party router you will need to consult your manufacturer or your manual to gain access to your router and find the necessary pages.
Please ensure you are using the following details:
Encapsulation Type: PPPoE (PPP over Ethernet)
Username: Username@plusdsl.net
Password: Your account password
Thanks,
MoR
Manickbarry42
Thanks not sure what happened but it’s working now 😁
