TP-Link AC1900 (Archer VR900 V2) Review -What does it mean?
- My Router
- TP-Link AC1900 (Archer VR900 V2) Review -What does...
05-06-2019 5:30 PM
I have been looking at reviews for the TP-Link AC1900 (Archer VR900 V2) router/modem. All reviews were good except this one. Can a router/modem genius translate this review for me?
Cheers
Gary
.... otherwise excellent router that leaves the front door open to hackers!
However, unless you are a tech genius who will lock down all internal machines with SPI firewalls, do not trust this router to protect your internal machines.
The SIP ALG (an automatic gateway to allow you to use a VoIP service) opens up port 5060 to the whole WAN and forwards it to the internal machine using SIP. The setting (and others similar) are enabled by default.
This meant that whilst thinking my internal machine was secure because it is behind a NAT firewall, the TP link router has forwarded all incoming connections directly to it. This has cost me a huge amount of money due to hackers making international phone calls.
I e-mailed TP-Link tech support and they have confirmed multiple times that this is expected behaviour of the ALG.
For their attitude towards security, this router goes from 5 starts to 0 from me.
Re: TP-Link AC1900 (Archer VR900 V2) Review -What does it mean?
05-06-2019 5:44 PM
Moderators Note
This topic has been moved from Fibre to My Router
05-06-2019 5:46 PM
05-06-2019 7:25 PM
That isn't true expected behaviour of a properly implemented SIP Alg. Having said that, most routers implementation of a sip Alg are broken in some way. In fact many (including the BT home hubs and the PN hub one) behave like the tplink. As @dvorak says it's not a problem unless you've got a device with port 5060 open i.e a VoIP device or software. I suspect you can also disable the sip Alg on the tplink whereas you can't on the BT hubs
05-06-2019 10:53 PM - edited 05-06-2019 10:57 PM
Hi Guys,
Thank you both for the updates. That raises two questions.
1. I use Skype and TeamViewer 14 (which allows PC to PC audio). Do either of these applications use VoIP?
2. Can you point me to a good tutorial re securing VoIP functions? I'll do a Google search now.
3. I'll check the tplink documentation re disabling the sip.
4. I'll run a port check to see if 5060 is open
Cheers
Gary
06-06-2019 7:16 AM
06-06-2019 8:06 AM
06-06-2019 9:04 AM
Disabling the sip Alg onnthe vr900
http://www.surevoip.co.uk/support/wiki/troubleshooting:sip_alg:tp-link_archer_vr900
06-06-2019 9:33 AM
Hi Guys,
Many thanks for your help. That is a simple fix for this sip alg problem so I'll order my VR900 today. I ran a port scan out of interest. Port 5060 was reported as being in 'stealth' mode.
Regards
Gary
06-06-2019 11:02 AM
I use a VOIP phone (Sipgate) with an old OBI100 ATA. My BT Business Hub 6 has SIP-ALG disabled. All works well. The inbound port on the ATA is set up to reject all calls except those from Sipgate.
The router tests stealth on all the relevant ports.
- My Router
