TP-Link AC1750 Dual Band Wireless Gigabit Cable Router
- My Router
- Re: TP-Link AC1750 Dual Band Wireless Gigabit Cabl...
12-03-2019 11:32 AM - edited 12-03-2019 11:34 AM
hi
i have this router added to my plusnet router so presumably a bridge as have multiple connections, plusnet wifi and 2 tp wifi connections.
I believe i can remove the plusnet router and just use this connected to the bt hub
do i just disconnect plusnet and connect the TP to the BT hub and then reset and setup?
setup through the tp app?
i was advised to just setup and use this:
Broadband username or login name: yourusername@plusdsl.net - the name i used to login here?
Connection type or encapsulation: PPPoE Always On
Password: The password you use to log in to the Member Centre
VLAN: Active
VLAN ID (802.1q): 101
VLAN ID (802.1p): 0
i was also advised that best to have the 2.4 and 5ghz network as the same name so devices easily switch between.
make sense?
i appreciate any assistance
once done i will have to then delete all my wifi bulbs and resetup but this shouldn't be an issue i think
thanks
Re: TP-Link AC1750 Dual Band Wireless Gigabit Cable Router
12-03-2019 1:35 PM
Hi @marc2
The above info which was provided should get you set up on a 3rd party router.
That's the one yes.
make sense?
This is completely up to you - give it a go both ways and see which works bets for you.
Let us know how you get on.
Kind Regards,
MoR
12-03-2019 1:58 PM
Not quite sure what you are referring to as the BT hub ? If you mean one of the Openreach moderns ( the hg612 or ECI versions) then you don't want to enable VLAN ID on the tp link as the OR modems handle it themselvrs
12-03-2019 2:01 PM
yes that probably what i mean the bt openreach fibre modem, ill check its model later
ty
12-03-2019 6:27 PM
You need to set the VLAN as inactive on the TP Link Router, the Openreach modem adds the VLAN tags on the DSL connection and will strip off any VLAN tags on its LAN1 port. Connect the LAN1 on the Openreach modem to the WAN port on the TP Link Router.
I've got a similar setup with a TP-Link AC1350 that works fine. You still need to setup PPoE with the plusnet username and password on the TP link router.
- My Router
