TP Link AC 1750 rourter settings for plusnet fibre?
- My Router
- TP Link AC 1750 rourter settings for plusnet fibre...
05-11-2018 6:20 PM
Hi Can anyone talk me through the full settings for a TP Link 1750 router for plusnet fibre account? I just cant get it to connect! Thank you!
Re: TP Link AC 1750 rourter settings for plusnet fibre?
05-11-2018 7:29 PM - edited 05-11-2018 7:32 PM
Normally TP link routers have auto detect option if not broadband username and password will be your sign in part what you use to view your plusnet account just remember to add @plusdsl.net at the end
I found this post on here this might be useful to you.
https://community.plus.net/t5/Fibre-Broadband/How-to-setup-TP-Link-router/td-p/1178170
Paul
05-11-2018 7:36 PM
@chapelbarn1 exactly which model have you got ?
I can't find a Tplink ac1750 that is fibre compatible
06-11-2018 7:24 AM
HI, Its an Archer D7 from TP Link. Thank you
06-11-2018 7:58 AM
06-11-2018 8:21 AM
@chapelbarn1 as @pjmarsh says , that router only has an ADSL modem, it won't work on a Fibre connection.
06-11-2018 11:54 AM
06-11-2018 12:08 PM
According to the TP Link website, the D7 also has an ethernet WAN port.
https://www.tp-link.com/uk/products/details/Archer-D7.html
You could use an external openreach VDSL modem with the D7 to connect to Plusnet fibre.
Search "HG612" on Ebay.
Richard
06-11-2018 2:41 PM
Alternatively you could use the Archer as a Wireless Access Point see https://www.tp-link.com/sa/faq-417.html for nothing. Remember to switch off the Plusnet wireless.
- My Router
