TP Link AC 1750 rourter settings for plusnet fibre?
chapelbarn1
Hi Can anyone talk me through the full settings for a TP Link 1750 router for plusnet fibre account?  I just cant get it to connect!  Thank you!
8 REPLIES 8
shrubbfamily
Re: TP Link AC 1750 rourter settings for plusnet fibre?
Normally TP link routers have auto detect option if not broadband username and password will be your sign in part what you use to view your plusnet account just remember to add @plusdsl.net at the end
I found this post on here this might be useful to you.
https://community.plus.net/t5/Fibre-Broadband/How-to-setup-TP-Link-router/td-p/1178170
Paul
Fixes: 395
@chapelbarn1 exactly which model have you got ?
I can't find a Tplink ac1750 that is fibre compatible
chapelbarn1
HI,  Its an Archer D7 from TP Link.  Thank you
pjmarsh
Fixes: 20
That’s an ADSL router isn’t it, not one for fibre?
Fixes: 395
@chapelbarn1 as @pjmarsh says , that router only has an ADSL modem, it won't work on a Fibre connection.
chapelbarn1
I see. Yes it’s ADSL. Thank you for clarifying.
RichardB
Seasoned Champion
Fixes: 39
According to the TP Link website, the D7 also has an ethernet WAN port.
https://www.tp-link.com/uk/products/details/Archer-D7.html
You could use an external openreach VDSL modem with the D7 to connect to Plusnet fibre.
Search "HG612" on Ebay.
Richard
Fixes: 419
Alternatively you could use the Archer as a Wireless Access Point see https://www.tp-link.com/sa/faq-417.html for nothing. Remember to switch off the Plusnet wireless.
