TP-LINK TD-W9980 N600
pinkbeef
can anyone tell me if this would work with my fibre connection, https://www.amazon.co.uk/TP-LINK-TD-W9980-Wireless-Gigabit-Storage/dp/B00NEQZ12Y/ref=sr_1_2?ie=UTF8&...
I have the Openreach modem DSL connection
thank you
2 REPLIES 2
bill888
Champion
Fixes: 36
Re: TP-LINK TD-W9980 N600
Yes is the simple answer.
If you search the forum, you will find many people using them.
You will need to enter your plusnet username & password, along with other parameters.
Instructions can be found here:
http://wiki.kitz.co.uk/index.php/TD-W9980_QuickSetup
A simulator is available here
http://www.tp-link.com/resources/simulator/TD-W9980(UN)/index.htm
ex-Plusnet (ADSL, FTTC) 2008-2023. now BT (FTTP) 2023-
pinkbeef
thank you
