TG582n firmware update
- My Router
- TG582n firmware update
25-06-2019 11:42 AM
Can anyone from Plusnet tell me if there has been a firmware update rolled out to the fibre version of the TG582n router recently. I have configured my printer to be a network printer using the USB port on the router, but print requests are not getting through
Re: TG582n firmware update
25-06-2019 3:21 PM
Thanks for getting in touch @maranello
There are no firmware updates we're aware of.
25-06-2019 3:42 PM
Thanks @MatthewWheeler
So likely to be either a win10 update or an inadvertent configuration change on my part.
I strongly suspect the latter, but I'll struggle to find what I did for the initial configuration.
27-06-2019 9:49 AM
For anyone interested, here is an update.
I deleted and re-added the printer as I believe I had done previously, as a network printer using TCP/IP port. Test print failed
I plugged the printer directly to my laptop via USB - this works.
I'm still none the wiser as to what has changed to prevent the printer from connecting to the network.
on 01-07-2019 4:36 PM - last edited on 08-07-2019 1:02 PM by Strat
If it helps, the following link explains how to configure the TG582n as a print server.
Moderator's note by Dick (Strat): Link removed at poster's request.
08-07-2019 7:59 AM
Really????
Don't click the link previous post
Did you deliberately add the dodgy link or has someone hacked your forum account?
08-07-2019 9:07 AM
That's a bit of a over reaction!
That link is to a PDF file download which explains in detail how to set up a Technicolor router as a print server.
I've just tested the download and although it's a bit of a faff it is the correct and legitimate file.
I spent some time and effort to find a file sharing site where I could put this file in the mistaken believe I may be helping you and I don't take kindly of you accusing me of posting a "dodgy link".
08-07-2019 9:36 AM
I'm sorry if I've offended you, it wasn't my attention. However, the site you linked to itself has links to what appear to be clickbait, and images that are not safe for work. That is why I described it as dodgy.
I appreciate the time and effort many on this forum take to help others out, and you are no exception, which is why I wondered if somehow it was not you who posted the link.
08-07-2019 12:45 PM
Still being puzzled by your reaction I have investigated further, and after disabling my browsers adblocker I can now see the adverts on the site.
I must say I agree the adverts shown on the site are not ideal for this forum and have therefore asked the moderators if they will please remove the link.
