TG582n Problem
- My Router
- TG582n Problem
TG582n Problem
19-12-2017 9:51 AM
Re: TG582n Problem
19-12-2017 10:25 AM
This might sound stupid but I assume that you are logging in to the router with the router password before trying to change the Plusnet password?
Re: TG582n Problem
19-12-2017 10:28 AM
Re: TG582n Problem
19-12-2017 10:50 AM
Have you tried a Factory Reset on the router by inserting a pin or similar in the appropriat hole, holding it in for several seconds then starting again with entering your user name and password etc. from scratch?
Re: TG582n Problem
19-12-2017 12:40 PM
You can request a reset or a reminder of your password emailed to you . It's time limited and the link sent will expire after an hour.
Go to the member centre here.
https://www.plus.net/index_nlp.html
click the forgotten password link.
Its dead easy !
Re: TG582n Problem
20-12-2017 8:21 PM
