TG582n Need remote access & to setup TLS.
JohnP2
TG582N Router, I need to login as admin at a remote site.
It has a static IP address.  I am sure I have done this in the past can someone remind me.
With Covid remote access becomes important.
Also I need to implement TLS for a  card machine, does anybody know where this  is?
JohnP
2 REPLIES 2
Fixes: 393
Re: TG582n Need remote access & to setup TLS.
This https://community.plus.net/t5/ADSL-Broadband/TG582n-remote-access/td-p/921425 should help with remote access.
You should consider any security implications of allowing remote access to the router on a site where card terminals are in use.
Nothing to do with the router, its down to the card machine itself to implement TLS
Fixes: 1,483
Moderators Note
This topic has been moved from ADSL Broadband to My Router
