TG582n FTTC - Port Forward Issues
FIXED- Subscribe to RSS Feed
- My Router
- TG582n FTTC - Port Forward Issues
28-04-2016 10:24 AM
Hi ,
I have tried and tried to port forward but can not seem to get them open , but if I use DMZ it opens the ports . I am trying to open port 3074 and whatever I do I can not open it. I have checked and double checked I'm doing it right .
Any further help would be really appreciated.
Rob
Fixed! Go to the fix.
28-04-2016 11:11 AM
There is a discussion on the gaming forum about port forwarding here which may help
Re: TG582n FTTC - Port Forward Issues
28-04-2016 12:08 PM
Thanks, but tried the suggestions and still no further
29-04-2016 9:56 AM
Can you describe (provide screen shots) exactly what you have tried?
Does the target machine obtain its address via DHCP?
29-04-2016 3:44 PM - edited 29-04-2016 3:44 PM
29-04-2016 4:08 PM - edited 29-04-2016 4:21 PM
Moderator's note by Mike (Mav)
I have reset the fix to SpendLessTime as setting a fix to your own problems without a detailed explanation as to the solution isn't helpful.
Forum Moderator and Customer
- My Router
