TG582N- ethernet LAN can't see wireless devices
- My Router
- Re: TG582N- ethernet LAN can't see wireless device...
02-02-2017 11:28 AM
Hello,
I have an ethernet lan connected via switch to the router.
My Win 7 PC internet view shows all ethernet devices but not wireless devices.
Should it?
David
Re: TG582N- ethernet LAN can't see wireless devices
02-02-2017 12:26 PM
Welcome to the forums!
Just so I can understand which page your looking at is it the router network map like the one below?
If so then I would only think wireless devices would come up on there whilst in use as opposed to Ethernet connections which would always be connected.
let me know if this is the page you were referring too and if loading up pages on a wireless device and refreshing the page shows the device?
Ben
02-02-2017 12:55 PM
Ben,
Thanks for your reply.
The view I was taling about is from the PC not the router....
PC Window 7 > File browser > networks. This show all connected ethernet devices but does not show my wireless devices.
David
02-02-2017 3:09 PM
ah in networks, in that case then it could be the switch and this limiting the things that show up on the network to only wired connections depending on the set up with the router and switch. Or could be the wireless devices not being set as discoverable or to show up on your home network.
If it that your trying to set up a home network or just see what devices are connected to your broadband?
06-02-2017 11:26 AM
I am trying to see what devices (wireless ) are conected to my broadband. I have now achived this by using FING on an android tablet.
David
08-02-2017 12:30 PM
I see, glad to see you've found an app/programme which will allow you to monitor that. If that method ever faults then you can always log into the router and see what devices are connected that way.
Ben
19-02-2017 11:49 AM
Have you checked if wireless isolation is enabled on your router? I don't know that model, but it's a common setting that effectively only allows wireless devices to connect to the network. If they are isolated, they wouldn't be able to respond to your Windows PC
- My Router
