TG582N Telnet
- My Router
- TG582N Telnet
TG582N Telnet
06-02-2018 3:29 PM
I wish to view the router's stats (speed, snr etc.) and Event Log; also, if available, graph or data for QLN.
Can I do any of that, please? What are the commands?
Re: TG582N Telnet
06-02-2018 4:13 PM
Have you looked at Routerstats (http://www.vwlowen.co.uk/internet/files.htm).
If you're using a windows computer you need to enable Telnet. Search for 'Windows Features' in the Control Panel.
Re: TG582N Telnet
06-02-2018 6:35 PM
Yes, I have,but actually I use DSLStats. The problem is that I've only temporarily reverted to the Technicolor while trying to solve a problem. With my usual router and DSLStats I can see much more.
Thanks for the Windows Features tip.
Re: TG582N Telnet
06-02-2018 6:46 PM
I've got to the little boxes, but am lost what to put next against "(admin)".
Re: TG582N Telnet
06-02-2018 9:33 PM
I assume that it needs your router admin username and password. It will need it to telnet the router.
Re: TG582N Telnet
03-03-2018 7:01 PM
@npr is the font of all knowledge on telnet and 582n routers; sadly his excellent website is in retirement ... but the wayback machine might help you find everything you ever wanted to know - https://www.waybackmachine.org/web/20160718103012/http://npr.me.uk:80/
Re: TG582N Telnet
04-03-2018 12:14 PM
DSLStats will work with the TG582N. If you having trouble setting that up I suggest you post on the Kitz forums.
Re: TG582N Telnet
04-03-2018 6:20 PM
@jelv Sorry to have over looked your post!I am using DSLStats but also RS at request of @Townman.
In passing, I must say that RS has improved, though I can not make out how and what to use user-defined graphs for.
