TD-W9980 setup
markhawkin
Fixes: 12
Re: TD-W9980 setup
@graemev
If cost is a major factor then for a while I used a Draytek 2820 and an Openreach VDSL modem I got from the well known auction site.
I ended up buying the 2860 because I wanted 2 extra built in Ethernet ports and greater throughput. The 2820 wouldn't quite do the throughput my VDSL line could manage (perhaps 55Mb/s whereas the line can do 68Mb/s).
The 2820 and Openreach modem was otherwise absolutely fine.
graemev
Re: TD-W9980 setup
One issue with the TD-W9970 is it's tp-link, which is the same brand as thee modem I have right now which is getting the problems (TD-W9980) ... anyone know who makes the Homehub5  ? My fears are around some nonstandard feature in the protocol stacks
graemev
Re: TD-W9980 setup
Cost is not really an issue, but lack of static routing means I simply cannot use HH5 (or the openreach you use) . There are other features I use now , like syslog, which I'd really like . The static route is the only issue (I can think of right now)  which just stops me using a given modem.
The tp-link box is cheap, but since they offer their PDF documents online I can see it offers the feature I need. The Draytek very proably offers the static routing , but I just happened to note there were lots of "issues" with the VDSL modem side; which is where my current problem exists (so little point in repeating that)
Fixes: 394
Re: TD-W9980 setup
@graemev The modem in the 9970 gets a good review on kitz https://kitz.co.uk/routers/tplink_TD-W9970_review.htm which is why I got it. I've no idea how it performs as a router though.
The HH5 is made by Sagemcom.
You can get the Draytek manuals from here https://www.draytek.co.uk/support/downloads
The 2860 does provide static routes , see page 225
 There's a couple of bargain 2830's on gumtree https://www.gumtree.com/search?search_category=all&q=draytek if you're anywhere near Corfe Mullen or Linlithgow or even a 2920 in West Yorkshire. Put the 9970 in modem mode in front of any of those as long as you don't mind 2 boxes (and can stand the looks of the 9970Grin)
markhawkin
Fixes: 12
Re: TD-W9980 setup
@graemev
For completeness, the Draytek 2820 was the router and I connected the Openreach device (a ECI Fibre Optic Modem from memory) as just a modem. That worked much the same as the Draytek 2860 from my experience.
Others like different devices but personally I like stuff that "just works", and by and large the Draytek fits that requirement.
I also like the way Draytek support their devices for a reasonable period of time but you do pay for that with the initial price.
graemev
Re: TD-W9980 setup
The Draytek (thanks for the link) does support static routes and much more besides, it's a much more serious modem/router so I guess that’s' as you'd expect.  The Sagemcom site suggests several of their modems do support "many features" (including static routes) but I can't actually find a manual for the "home hub" (to be expected I guess) . When I first joined "Force9" I was given a Billion router . This had the ability to ssh onto the box and configure in a manner similar to the Cisco IOS . I wonder of the HH5 has a similar "back door" to allow more features to be accessed?
Fixes: 394
Re: TD-W9980 setup
@graemev Nope, it's pretty much 'locked-down'.
As you say , The Draytek's are much more serious pieces of kit. I use them in the office (2820s still) for VPN tunnelling to client sites for remote support. Only problem I've had in about 4 years is a PSU went the other week. I've got  spare 2820 so just swapped the PSu but then got a couple of compatible PSU's from CPC for about £6,
On my 2830 at home I use, wifi scheduling to turn wifi off at night, for a VPN tunnel to the office and also to set some static DNS entries.
