Switching from 2.4GHZ to 5GHZ
Merv1
Hi, new to the forum.
I have the Plusnet supplied router (Sagecom 2704N) and I can't see how this can be switched from 2.4GHZ to 5GHZ.
The 2.4GHZ band is getting crowded! However, when I go to advanced settings, WiFi I can't see any options to switch bands, only channels? Am I doing something wrong or does the router not offer this band switching feature?
2 REPLIES 2
agedgopher
All Star
Fixes: 15
Re: Switching from 2.4GHZ to 5GHZ
The router you have is a single band router so you have no 5Ghz provision. Sorry
Merv1
Hi, agedgopher. Thanks for your reply, my 2.4GHZ band is beginning to get crowded. So, looks like another router!
Kind Regards and keep safe.
