Struggling to connect old router to new PlusNet hub
Verbalist
PlusNet have just sent me a new hub to replace my old OpenReach modem, and now I'm struggling to connect my (Netgear) router to it.
Will someone kindly tell me if I should be using the new hub's WAN socket or one of the hub's other Ethernet sockets?
5 REPLIES 5
Fixes: 382
Re: Struggling to connect old router to new PlusNet hub
The Hub2 is a combined modem/router - why do you need to connect the Netgear?
Verbalist
Thanks for asking.
Our house has thick brick internal walls and also has had a long extension so I got the Netgear mesh system to extend the wifi. With the old OpenReach modem our wifi coverage was good, and I'd like to have that coverage back.
That's why I asked if I should be using the WAN socket or one of the three ethernet sockets.
Fixes: 382
OK, so the Netgear is a mesh system, and you want to use the Hub2 in modem-only mode? In which case, the connection to the mesh system is via one of the LAN ports.
Verbalist
Great - many thanks
Fixes: 1,495
Moderators Note
This topic has been moved from Broadband to My Router
