Strange mobile phone connection issue
- My Router
- Strange mobile phone connection issue
14-08-2021 2:43 PM
Moved over to Plusnet from BT about a week ago.
Our smart TVs and laptop connect to the Wi-fi wirelessly with NO issues!
However both my partner and I’s mobile phones are having issues. We are fully connected to the Wi-fi but internet just stops responding completely after about 30 secs of use and can’t load pages, videos etc. Find this bizarre as all other devices work fine. We’ve just been using our phone data the past week. Anyone got any ideas?
Thanks!
Connor
Re: Strange mobile phone connection issue
14-08-2021 3:27 PM
Moderators Note
This topic has been moved from Fibre to My Router
14-08-2021 3:35 PM
You could try splitting the 2.4 and 5GHz wifi bands, it helps with Apple products.
Navigate in a web browser to 192.168.1.254.
Click Advanced Settings
Enter your Hub admin password when prompted (unless you've changed it, you'll find the default password on the settings card)
Continue to Advanced Settings.
Click on Wireless.
Click 5GHz tab.
Change 'Sync with 2.4Ghz' to No.
Change the name of the 'Wireless SSID' - I added a '_5' on the end.
Save the changes.
You can then select which one you want per device.
14-08-2021 3:36 PM - edited 14-08-2021 3:37 PM
Dvorak beat me to it...
14-08-2021 4:12 PM
Put your BT Hub back and use that. See links from here for the settings https://community.plus.net/t5/My-Router/Using-A-BT-Smarthub-An-Update/m-p/1795292#M24601
14-08-2021 5:56 PM
I completely agree with this. The BT one works much better and is compatible with Plusnet.
14-08-2021 6:44 PM
- My Router
