Static ip address not set.
- My Router
- Static ip address not set.
23-03-2019 10:53 AM
So, new plusnet customer, mover from sky fibre pro.
When I moved over to plusnet, I asked about the use of a static IP address. I paid my £5 and was told it was done.
I've have multiple IP changes during the first month of service. Can someone please inform me as to when the static IP will be applied?
Message 1 of 3
(440 Views)
2 REPLIES 2
Re: Static ip address not set.
23-03-2019 12:51 PM
Hey @Passat52
Do you mind dropping me a PM with your Plusnet username so I can check into it for you?
thanks
Message 2 of 3
(424 Views)
23-03-2019 1:04 PM
Many thanks for your message. Please disconnect and reconnect and you should find the IP is now assigned
Message 3 of 3
(416 Views)
