Static IP
natedogg457
Static IP
Hi im trying to configure my static IP to work with my hard drive which is plugged into my plus net hub one but i cannot find the setting in the router control panel i done a IP search and i found my hard drive is listed as 192.168.1.254 which is the router panel how do i get my router panel to forward to my static ip?
7 REPLIES 7
Fixes: 1,483
Re: Static IP
Not sure what you're trying to achieve here, the harddrive will always be available at \\192.168.1.254 in windows explorer.
you can map a network drive to that if required.
natedogg457
Re: Static IP
i want to make it via the static ip
natedogg457
Re: Static IP
and i want to make localhost to static ip
Mustrum
Fixes: 77
Re: Static IP
Which router do you have? I assume you have plugged the drive into the USB port, which has limitations. You may be better with a decent NAS connected to an Ethernet port.
natedogg457
Re: Static IP
plusnet hub one
Fixes: 1,483
Re: Static IP
when I asked what you wanted to achieve was it was whether you wanted to access it externally.
you won't be able to do that with the hub one. internally it's always accessible on 192.168.1.254
natedogg457
Re: Static IP
What about a NAS.
