Static IP
- My Router
- Static IP
Static IP
12-04-2016 6:04 PM
Hi im trying to configure my static IP to work with my hard drive which is plugged into my plus net hub one but i cannot find the setting in the router control panel i done a IP search and i found my hard drive is listed as 192.168.1.254 which is the router panel how do i get my router panel to forward to my static ip?
Re: Static IP
13-04-2016 9:17 AM
you can map a network drive to that if required.
Re: Static IP
28-04-2016 6:17 PM
i want to make it via the static ip
Re: Static IP
28-04-2016 6:28 PM
and i want to make localhost to static ip
Re: Static IP
28-04-2016 7:39 PM
Which router do you have? I assume you have plugged the drive into the USB port, which has limitations. You may be better with a decent NAS connected to an Ethernet port.
Re: Static IP
28-04-2016 9:44 PM
plusnet hub one
Re: Static IP
28-04-2016 9:54 PM
you won't be able to do that with the hub one. internally it's always accessible on 192.168.1.254
Re: Static IP
12-08-2016 11:00 AM
What about a NAS.
