Solid Red (internet) light on Router
BillN
Interested
The internet is working as normal ..... but a couple of days ago the (internet) light on the Router, (TG582n) turned solid red and has stayed that way.
Software Release on Router is 8.4.4.J
is there a problem
is there a more current firmware release
3 REPLIES 3
BillN
Interested
Re: Solid Red (internet) light on Router
just to add - I have done nothing to the settings - no change of password or anything like that
Mav
Fixes: 497
Moderator's note:
Moved to appropriate board.
Forum Moderator and Customer
Fixes: 271
For latest firmware this might help https://community.plus.net/t5/My-Router/Is-my-TG582N-firmware-u-t-d/m-p/1477586#M4179
You tell us if you have a problem, is your broadband working? If so what do you get if you do a speed test and how does this compare with previous results?
