Smart Hub 6A & BT Wifi/FON
- My Router
- Smart Hub 6A & BT Wifi/FON
28-08-2020 10:24 AM
Just wondered if there's any way to disable this? It's 'on in my router CP & there's no way to change that. Hoped factory reset might do the trick but it didn't. The only other suggestion I found was to disable it through your myBT account which I don't have as I'm with Plusnet. So pretty stuck really.
Message 1 of 2
(202 Views)
1 REPLY 1
Re: Smart Hub 6A & BT Wifi/FON
28-08-2020 12:00 PM
Whist you can’t disable it in the settings other users of residential versions of the Smarthub 6 report that it is not in operation when connected to a Plusnet service, so just ignore it.
Message 2 of 2
(190 Views)
