Settings - Backup and Restore - file selected is not a valid configuration file for your Plusnet Hub
- My Router
- Re: Settings - Backup and Restore - file selected ...
09-06-2018 11:49 AM
The file selected is not a valid configuration file for your Plusnet Hub.
I have copied the 'Subject' line here as the input of HTML and then checking of how it looks using preview discards all that I have typed - extremely irritating!!!... Subject:
Re: Settings - Backup and Restore - file selected is not a valid configuration file for your Plusnet
09-06-2018 2:13 PM
Is this connected with this post? https://community.plus.net/t5/My-Router/Replacing-what-I-assume-is-a-PN-Hub-1-with-the-latest-versio...
I assume that this backup and restore feature is designed for changing like for like routers but don't understand why anyone would bother. If you change the SSID and passwords to align this with an old router then the card and label with the necessary data becomes useless unless you do a factory reset.
With WPS features on most wireless devices would it not be easier to reset all your client devices? Failing that I would expect that if you go into the router advanced settings you can change things manually.
- My Router
