Self assigned IP address on ethernet cable with plusnet hub one on Mac
jaspertrevelyan
Think may have posted this on the wrong board, so trying again:
I have an iMac running OS Catalina, although the same issue was there before the recent OS upgrade
I have a new plusnet hub one router, with an ethernet directly to the iMac
In network settings, the wifi works fine, but the ethernet has the following message and won't connect:
"Ethernet has a self-assigned IP address and will not be able to connect to the internet."
I've tried up working through the network settings options: made sure it is "configure IPv4", using DHCP, renewed DHCP lease, tried setting up a new location (default one is automatic) and renewing DHCP lease on new location - no effect.
I'm coming to the conclusion it is a router issue. Any ideas?
Many thanks, Jasper
5 REPLIES 5
markhawkin
Champion
Fixes: 22
Re: Self assigned IP address on ethernet cable with plusnet hub one on Mac
Well Jasper,
The issue (as you have correctly identified) is a failure of DHCP on the cabled connection.
Why I can't explain.
As a workaround, you could assign a static IP address (say 192.168.1.60), Subnet 255.255.255.0 and gateway 192.168.1.254 on the iMac.
If you have another router that will work with Plusnet (say a BT home hub) you could also try that.
I would also try a different cable between the iMac and the router and a different hole on the router.
Bill_C
"Self Assigned" address means that for some reason it can't see the router/DHCP server.
First thing is : Try another network cable and plug it directly into the router if possible.
Then you could try a "Fixed IP" address:
IP Address = 192.168.1.10
subnet mask = 255.255.255.0
Gateway = 192.168.1.254
See if the fixed Network address gives you internet access.
jaspertrevelyan
Thank you Mark
I'm slightly embarrassed. Changing the cable sorted it out. Should have tried that first I guess.
Anyway, it's saved me more head scratching, so thank you very much!
Best wishes, Jasper
jaspertrevelyan
Thank you Bill
Best wishes, Jasper
markhawkin
Champion
Fixes: 22
Hello Jasper,
Don't feel bad, it's a hole I've fallen down before, looking for a complex fault when the problem is simple.
I consider it a "learning experience" !
