Securing the WiFi password on my router
- My Router
- Securing the WiFi password on my router
- « Previous
- 1
- 2
- Next »
Re: Securing the WiFi password on my router
10-02-2018 2:49 PM
I popped into the front room just now and discovered my router with the red light showing. On my screen I saw a message about having to reconnect to my router. I tried to do this and after 3 attempts was informed that my password was incorrect. I then did a factory reset on the router and am now able to access the router with the original password. Does that mean that someone had temporarily succeeded in changing my WiFi password.I find that difficult to believe as I don't think that the person under suspicion (hereinafter known as PUS, quite approriate!) has that much technical chops.
Or is it possible that my router is spontaneously resetting its password, and also switching off spontaneously as apparently happened earlier. After reading some of the tales of woe about router problems on these boards, I haven't rule out that possibility either.
10-02-2018 3:09 PM
@Anonymous
Yes, you are missing something. What Oldjim claimed was:
Note that if a device is connected via a LAN cable they can read the wireless password but this applies to all routers
I suppose it may be technically true to say that if your computer has a 27 inch monitor then you can crack the wireless password, but the size of the monitor is actually irrelevant - as is the LAN cable connection to the router with all those methods of cracking the wireless.
10-02-2018 3:11 PM
I realised that and I'd just edited my post prior to your post.
10-02-2018 4:12 PM
Who knows? If it happens again then go into the admin pages and see what password is set.
I see that there are BT Smart Hub 6s going today on Ebay for around £30. You could always buy one of these, scrape off the label fixed to the back and start again with a much better router. Obviously you still have a problem if PUS has an Ethernet cable.
I still favour locking it in a box or cupboard!
10-02-2018 4:57 PM
You could ask if it is possible for Plusnet to disable the reset button on your router (the Technicolor 582n had this capability).
10-02-2018 9:32 PM - edited 10-02-2018 9:34 PM
Re logging in using the router password - this is why I mentioned it - and I assume this is where it is but I don't know if the card is removable
If you want to view or change any settings on the Hub Manager pages, you'll need the Hub Admin password. You'll find this on the card stored on the back of your Hub.
- « Previous
- 1
- 2
- Next »
- My Router
