Sagemcom Plusnet Hub One WAN port as LAN
FIXEDTopic Options
- My Router
- Sagemcom Plusnet Hub One WAN port as LAN
30-11-2020 7:48 PM
Good evening Ladies and Gentlemen,
Please can the 5th RJ47 port (WAN) be turned into a 5th LAN port? I have seen this feature on some of the other routers.
P/N: 253633882
Otherwise I get a network switch.
Please advise.
Thank you
Best regards
Fixed! Go to the fix.
2 REPLIES 2
06-12-2020 8:19 PM
@Kardell - this isn't possible I'm afraid, so acquiring a separate switch is the way to go.
Re: Sagemcom Plusnet Hub One WAN port as LAN
06-12-2020 10:22 PM
ok, cool, thank you for letting me know.👍
- My Router
