Sagemcom 2704N won’t connect
- My Router
- Re: Sagemcom 2704N won’t connect
12-07-2019 9:45 PM
Tried old Technicolor 582n to see what happened and it connects no problem! Anyone have any ideas why the Sagemcom won’t?
12-07-2019 10:08 PM
Welcome to the forum.
It might not be picking up your Plusnet username and password from Plusnet servers. Try a factory reset by pushing a paperclip or similar into the reset hole. Keep the switch closed for 20 seconds or so and leave it for 10 minutes or so.
If that doesn’t work go into the settings and manually set it up. Be aware that the WiFi performance of these devices is dire. Many people go onto EBay and get a BT Smarthub 6 for little money. You will find the setting instructions at the top of this board.
12-07-2019 10:20 PM
13-07-2019 10:31 AM
I have never used one but I understand that the Technicolor router has more setting options then the Hub Zero and I doubt that its wireless performance is any worse.
The Hub Zero is a very basic, cheap, single wireless band, minimum cost bit of kit that's been locked down to make it as idiot proof as possible. It's obviously been chosen in order for Plusnet to give a router away with their lowest cost service. When people look at comparative costs the quality of the freebie modem/router will rarely be taken into consideration.
- My Router
