Sagecom 2704N firmware update.
tomdooley999
Hello to you all. This is my first post in the community and i would like a little help if possible.
Would someone be able to update the firmware on my Sagecom 2704N Router?. The firmware version we have at present is 7.275.6_F2704N_Plusnet.
Thank you in advance.
4 REPLIES 4
OskarPapa
Fixes: 65
Re: Sagecom 2704N firmware update.
Hi @tomdooley999, thanks for your post and welcome to our Community.
Is there a specific reason you'd like to get the firmware updated?
The reason I ask is that we often find that our customers request updates due to ongoing technical issues and so if that is the case we'd 100% look to troubleshoot the issue first.
bobpullen
Fixes: 306
@tomdooley999, I've pushed the latest available firmware to your device.
tomdooley999
Thank you for taking the time to reply. I seemed to be having problems with WiFi connectivity range and now that I've received the latest update, maybe this will help. Thanks again.
tomdooley999
Thank you bobpullen for you help. I'll see if the firmware update helps with my wifi connectivity problem. Thanks again for the update.
