SSID
howardl
SSID
Where do I find the SSID on the router?
2 REPLIES 2
Fixes: 392
Re: SSID
It is on the card supplied with the router and/or on the sticker on the same - starts with PLUSNT- (then a random string).
Re: SSID
@howardl
If you are asking where you can find and change the SSID in the Hub's GUI, (assuming Hub2?):
Type 192.168.1.254 in to a web browser's address bar.
Navigate to Home > Advanced Settings > Wireless and both the "Network Name" (aka the SSID), and the "Security Password" (ie the WiFi password - not the Hub's Admin password), can be changed there.
