SSID
yorkie23
SSID
I have just noticed that my SSID is no longer broadcast and is now hidden. Why has this happened, is it important and how can I change it back.
Performance is not effected.
Geoff
1 REPLY 1
bobpullen
Fixes: 330
Re: SSID
Hi Geoff,
From what I can establish at this side, both SSID's are enabled and broadcasting Huh
If things still don't seem right at your end then I'd try powercycling the router, and if that doesn't help - maybe attampt a factory reset by inserting something into the pinhole at the rear of the device until the status light flashes green.
