SSID keeps dropping
FIXED- Subscribe to RSS Feed
- My Router
- SSID keeps dropping
27-12-2018 10:42 AM
For some reason, my SSID just disappears and I lose all connections, the only way to recover is to reboot the router, this is happening on an irregular basis so I can't pin it down to any particular situation or activity, any ideas?
Fixed! Go to the fix.
Re: SSID keeps dropping
27-12-2018 12:27 PM
Hi @scwass, thanks for your post.
We're sincerely sorry to hear of the issues affecting your router.
Are you currently using any Amazon Fire devices, at all?
27-12-2018 12:32 PM
no, I have an amazon echo, but every time the SSID disappears. I see https://dbtpnhdm.bt.mo appears in the event log, it almost seems a request goes out and that seems to start the issue off
27-12-2018 1:17 PM
Moderator's note:
Topic moved from Broadband to My Router.
Customer and Forum Moderator. Windows 10 Firefox 86.0 (64-bit)
27-12-2018 2:20 PM
Hi @scwass,
Thank you for confirming that. This issue could potentially be due to your router's firmware. Please can you confirm which version of firmware your router is on at the moment? You can find this by going to http://192.168.1.254 to bring up the router interface. The firmware version is at the bottom of the page.
27-12-2018 2:32 PM
27-12-2018 3:20 PM
I've just updated our back end system which should resolve the firmware issue for you, by pushing it back to the shipped firmware version.
I've also requested that a fixed version of the newer firmware be pushed to the router ASAP. Our products team will email me when they've pushed it through, at which point I'll update you directly.
In the meantime, please don't hesitate to get back in touch if you need help with anything else at all.
09-01-2019 1:21 PM
@scwass, I've just pushed a software update to your device that should fix this?
21-01-2019 4:31 PM
this seems to have fixed the problem, do you want me to return the replacement router that was sent out?
Shaun
21-01-2019 4:39 PM - edited 21-01-2019 4:40 PM
Please. Do you have a returns bag, or would you like me to send one?
