Router
smithy3
Router
Hello!
I've got a Hub 1 which has patchy coverage in my house, so trying to extend it.
I've ordered this: TP Link router but I've attached it to the Broacgband/ Wan connection (I think that's the right one). I go to set it up as an access point in the TP software, which is all works fine except that it's not getting a signal from the Plusnest router.
Any ideas how to fix this? Thanks in advance!
3 REPLIES 3
Fixes: 585
Re: Router
It needs to be connected to a LAN port on the Hub 1 not the WAN port
Browni
Aspiring Hero
Fixes: 61
Re: Router
You need to connect the TP-Link router to one of the LAN ports on the Hub One.
eta: @MisterW types faster than me 😁
smithy3
Re: Router
I could swear I tried that , but obviously not! It's all up and working. Thank you so much!
