Router
fredwil2
Router
HI,
I have used Plusnet for many years. I have just changed my package to Unlimited Fibre Extra which stats on 16/8. Do I need to get another router or use the same one that I have?
Thank you.
8 REPLIES 8
Fixes: 1,481
Re: Router
Moderators Note
This topic has been moved from Chat to My Router
Fixes: 1,481
Re: Router
Do you know which router you have now?
Normally one would be offered as part of the upgrade process.
fredwil2
Re: Router
Its just the normal router that I gor years ago when I joined Plusnet.
Fixes: 1,481
Re: Router
I suspect you’ll need a new one and should have been offered it in the sign up process.
Can you see anything on your order status page?
fredwil2
Re: Router
Under Hardware its just got No.
fredwil2
Re: Router
How do I order a new router?
Fixes: 401
Re: Router
@fredwil2 wrote:
What constitutes normal is the question. If it’s a hub one or you are moving from fibre to fibre extra then it’s the same hub. If you’re moving up from ADSL then you need a new one.
adam945
Fixes: 113
Re: Router
Hi @fredwil2
As you're remaining on FTTC, you wouldn't need a new router unless the one you have at the moment is found to be faulty.
 Adam
 Plusnet Help Team - Leeds
