Router
pwarrilow
Router
Hi Guys,
         Dinosaur here,,, Because of 'you know what' going on at the mo,we could do with the router signal having more range.
Our house isn't particularly big but the old pnet router signal is poor in range,, We got a signal booster but got in a complete pickle with it,and also found our router was not resetting very well when messed with.So they are sending a new router,,,Will a newer pnet router have a better range? We also got hold of a bt router and a sky one, but can they be used,and if so is it possible that a stegosaurus could sort it ? Thanks ,Dino
1 REPLY 1
Fixes: 391
Re: Router
@pwarrilow
You don't say which service you are on or that other routers you have.
I don't know about Sky Devices but BT Home Hubs and Smart Hubs can all be configured to work on both Fibre and ADSL Home Hubs 2, 3 and 4 only work on ADSL.
Many of us use BT Smarthubs as they are far better devices than the Plusnet offering.
Helpful links:  https://community.plus.net/t5/My-Router/Use-a-BT-Hub-2-3-4-or-5-on-a-Plusnet-connection/m-p/1192234#...
https://community.plus.net/t5/My-Router/Using-the-BT-Smarthub-6-on-a-Plusnet-Account/m-p/1587673#M85...
