Router
Victormildrew
Router
Hi. Just joined PlusNet, this may sound silly, the blue light on my router is really bright and lights up the whole of the lounge, when I watch tv I like it dark,can the light be toned down in anyway or could I just cover it up with some black tape.
Thanks.
3 REPLIES 3
Fixes: 1,485
Re: Router
Moderators Note
This topic has been moved from Fibre to My Router
Fixes: 1,485
Re: Router
You can't turn the light off completely, though it can be turned down a bit in the web interface.
Covering it with tape is fine.
OskarPapa
Fixes: 65
Re: Router
Well once again, thanks for that @dvorak!
@Victormildrew - Did you need anything further or is everything now resolved?
