Router
- My Router
- Router
Router
on
14-04-2019
9:04 PM
- last edited on
14-04-2019
10:58 PM
by
Strat
Hi
My parents router has stopped working.
How can I go about ordering a new one for them?
My parents username is [Removed].
Moderator's note by Dick (Strat): Personal information removed from a public forum (to an area that staff can see).
Re: Router
14-04-2019 10:35 PM
A 2nd hand BT or PlusNet off E bay would suffice.
Re: Router
14-04-2019 11:00 PM
This topic has been moved from ADSL Broadband to My Router.
Customer and Forum Moderator. Windows 10 Firefox 85.0.2 (64-bit)
Re: Router
15-04-2019 10:42 AM
The router in question is still within warranty, so we'd potentially be able to replace this depending on the fault - could you please let us know what's gone wrong with the router so we can assist?
Best wishes
Dave
Re: Router
on
15-04-2019
11:11 AM
- last edited on
15-04-2019
11:44 AM
by
Strat
Hi
The router is for my parents. They currently have a flat Thompson box.
They have never had any problems and have had the router since they joined Plusnet many years ago. It has just suddenly stopped working. No lights, dead. Tested everything and had some one else check as well but it's not coming back to life!
Their user name is [Removed] if you are able to check their records for how old the router is.
Re: Router
15-04-2019 11:16 AM
That router is definitely out of warranty by a considerable margin!
As previous posters have advised, your parents could replace the router independently, or, if they speak to one of my colleagues in our Customer Options Team, they may be able to negotiate a new contract that would come with a new router. My colleagues can be contacted on 0800 328 4624.
Just a note - you may want to edit your original post to remove the username for your parents account
Best wishes
Dave
Re: Router
15-04-2019 11:35 AM
How do I edit my post?
Re: Router
15-04-2019 11:38 AM
Re: Router
15-04-2019 8:21 PM
While getting a new router is the best answer, with no lights on at all, my first guess would be that the PSU "brick" has failed.
If you have a spare similar PSU (same voltage) it might be worth a try.
Otherwise, if anyone you know has a spare old BT router that can be made to work.
Obviously nicest is getting a replacement from Plusnet with a new contract, that will just "plug in and work"
Re: Router
15-04-2019 8:48 PM
Thanks for everything one's help. You've all been great!
Re: Router
16-04-2019 9:10 AM
Just a quick addition to this one, @fullofflowers - if you do manage to get hold of another router in the interim, just drop a line here detailing which one it is and someone will be able to help you with the details you need to set it up.
Best wishes
Dave
