Router wont show ethernet connected device
hunters2016
Hi All,
I have a sagemcom 2704N plusnet router.
I have a slight issue, im trying to connect a door entry system into the router so allow me to connect to the entry system remotely. this is something that was set up on a net-gear router previously and is done by setting up a port forwarding rule on the router.
the problem i have is that the entry system although connected via Ethernet to the router is not showing up in the "my devices" therefore i cannot assign a port forwarding rule to it as a device.
i believe this is because the entry system has its own static IP address within it and the router is configured as DHCP only and therefore is expecting to allocate IP addresses to all the devices it has connected to it automatically. i need to attach this device with its static IP address and remove this address from the reserved list of IP addresses currently within the router.
Does anyone have any suggestions? Smiley
2 REPLIES 2
bill888
Champion
Fixes: 38
Re: Router wont show ethernet connected device
Port forwarding only seems to work on recent Plusnet routers if the connected device can use DHCP.  It's a known limitation with the firmwares.
If you cannot use DHCP, then unfortunately the only solution is to use a 3rd party router, such as your previous Netgear.
ex-Plusnet (ADSL, FTTC) 2008-2023. now BT (FTTP) 2023-
hunters2016
Hi Bill,
Not the answer i wanted however its helped me decide how to work around it, thankyou very much
