Router wifi doesn't reach outside of the room it's in!
- My Router
- Re: Router wifi doesn't reach outside of the room ...
02-05-2017 11:24 PM
Re: Router wifi doesn't reach outside of the room it's in!
03-05-2017 8:10 AM - edited 03-05-2017 8:11 AM
Perhaps try switching off the 5 ghz band on what I assume is HubOne router; it has worse distance performance
than the lower band. Devices will then only see that; does it help?
Otherwise get a cheap plug in range extender.
eg
https://www.amazon.co.uk/NETGEAR-WN3000RP-200UKS-Universal-Extender-Indicators/dp/B00NIUHA84/ref=sr_...
03-05-2017 10:45 AM - edited 03-05-2017 10:45 AM
Welcome to the forums.
Assuming you have a smart phone/tablet, you might want to try to map out where in your flat the signal is best. There are plenty of good free apps (On Android I recommend "Wifi Analyzer" by farproc)
This webpage will help you to go through the task https://www.cnet.com/uk/how-to/how-to-optimize-your-wi-fi-network-with-wifi-analyzer/
03-05-2017 1:32 PM
03-05-2017 1:46 PM
03-05-2017 2:22 PM - edited 03-05-2017 2:22 PM
Okay.
How far can you move the router without unplugging it? Can you raise it up by say a 1 metre or move it to the left or right of where it is currently?
Also does the orientation of the router make a change in the signal strength? i.e turn it 180 degrees or 90 degrees.
And is there a DECT phone (wireless house phone) or baby monitor or microwave within a few feet of the router? All those devices can cause issues with WiFi signals.
And finally is the result for signal strength the same on the 2.4GHz band and the 5GHz band (assuming your Plusnet router is a dual band model)
03-05-2017 2:23 PM
WiFi reception can be a dark art!!! The attached link gives tips for boosting performance.
03-05-2017 2:35 PM
03-05-2017 2:59 PM - edited 03-05-2017 3:01 PM
You still haven't confirmed Router type you have + whether a dual band one.
There may be something odd about your topography; £20 investment in an Extender is money well spent if it fixes your situation. If it doesn't work you can get refund, and consider investing in another Router.
03-05-2017 5:18 PM
Loss of signal so quickly is unusual. Assuming it is a modern flat in a purpose built block so it would have a lot of metal in all the walls but the signal should still go for a few feet at least.
It might be the Gel's advice is the only way to go if the building is damping the WiFi that quickly.
03-05-2017 5:51 PM
It's the standard fiber router that plusnet send out. While an extender would fix the problem, it's the point that it shouldn't be a problem in the first place, surely a standard issue router should be able to reach through most of a house yet I can't get it to reach outside of a room? I've been trying to get this fixed with plusnet since getting it put in in january and their solve-all solution is "change the channel" which doesn't work. While I appreciate the advice and help given here, still nothing seems to work? To me, this says something is wrong but how to find out what?
03-05-2017 6:08 PM
To prove/disprove the router, could you take it to a friend/parents' house who has fibre and swap it for their working one. Then check if the WiFi works across a wide physical range. I know the property might well be very different to yours but at least you can see if the router's WiFi functions better elsewhere.
If it works well then it is the building you live in causing the signal to attenuate quickly. If not, then you may have a faulty router and could ask Plusnet to swap it for you.
03-05-2017 6:14 PM - edited 03-05-2017 6:15 PM
In defence of ISP's. WiFi reception is not their job - they provide a router which, so long as a WiFi signal is being transmitted, completes the contract. They cannot possibly know what WiFi is like at each location or the cause of any problems.
PlusNet is a value (basic) internet provider and as such provides a cheap router. For some it does the job, for others it doesn't. You are receiving a signal (abet at close range) so in theory the router is working. It's also the second one you've tried without the signal improving.
Hardware, like software, doesn't always work well together - it could just be your WiFi device. Try any other's you may have to see if that makes any difference.
- My Router
