Router went bang with a big flash
- My Router
- Router went bang with a big flash
13-08-2020 11:20 AM
Hi, my Plusnet Hub One went bang with a big flash just before a large lightning strike. It now won’t power up. The adapter works in other devices so that’s ok.
What type of router do I need to replace it?
I’ve tried an old TG582n but that just flashes green I guess because I’m now on fast/Fiber and that’s non VDSL.
Can’t get through to tech support!
Labels:
Message 1 of 2
(303 Views)
1 REPLY 1
Re: Router went bang with a big flash
13-08-2020 12:06 PM
Get a BT Smarthub 6 from an auction site such as Ebay. They are cheap and better that the Plusnet hub. You will find the setting instructions pinned at the top of this board..
Message 2 of 2
(282 Views)
- My Router
