Router username and password not recognised
- My Router
- Router username and password not recognised
18-07-2016 6:20 PM
My daughter visited recently and had a problem using my home wifi connection. She was using a new Surface Pro 4 with the Win10 fully updated.
The problem was she could see the access points (I have two) but neither would accept the password for the sign in if it was typed directly into the sign in from the network fly out screen. It could connect with a wired ethernet and a usb adapter. The second router is just a repeater for better coverage and is wired to the Plusnet one.
However, the problem was resolved by typing the password into Notepad first then cutting and pasting it into the password box on the network flyout screen. We tried this several times and it was completely repeatable so no typos with the direct input!
She was later able to sign in to her brother's BT router without any problems either.
Please could someone explain that is happening here. She has not had a problem with wifi connection elsewhere such as airport etc, which suggests its my router/network.
Re: Router username and password not recognised
19-07-2016 4:57 AM
Does your wireless password contain any spaces or characters other than letters of the alphabet and numbers?
Sounds like a bug in Windows 10 for Surface tablet, given that you witnessed the issue with both your router and repeater which use firmwares from different manufacturers.
19-07-2016 7:34 AM - edited 19-07-2016 7:37 AM
Possibly what looks like a '6' is actually a 'b' or vice versa,
or a '5' is really an 'S', a '0' is maybe an 'O' etc....
I did once struggle for a while with a password where an apparent '8' turned out to be a 'B'.
Some fonts can look ambiguous.
FTTC 40/10 Billion 8800NL
BT technician (Retired)
19-07-2016 8:14 AM
Thanks for the thought but you would make the same mistake on Notepad but that worked, so not the answer.
- My Router
