Router upgrade
srwpchelp
Interested
Router upgrade
I have a Plusnet Hub One Router. It’s located right by the BT socket in the hallway. I use a Netgear extender to receive a reasonable signal in my conservatory & garden. I’m considering replacing the router with a better one with the sole intention of removing the need for an extender.
I’ve already done some research but would appreciate some recommendations from other Plusnet users who’ve decided to ditch their router. Speed isn’t an issue it’s range. Distance to the bottom of the garden is about 100 feet
Gaming is not important. Neither is number of devices.
Thanks.
2 REPLIES 2
Strat
Fixes: 564
Re: Router upgrade
Moderators Note
This topic has been moved from Fibre Broadband to My Router.
Customer and Forum Moderator. Windows 10 Firefox 103.0.2 (64-bit (64-bit)
Longliner
Fixes: 7
Re: Router upgrade
I find that range depends on whether there is line of sight from router to target, thick walls such as ours in between mean you've no chance! I've had about 20% better wifi with a second-hand £15 BT HH6 replacing the PN Hub One. However, if your Netgear is not broke do you really need to fix it?
