Router upgrade - recommendations ?
MattyBoo
I'm still using the Technicolor 582n router that was supplied when I upgraded to Plusnet Fibre some years ago.
It's not coping very well with the increased number of devices since my kids grew up and started watching youtube and gaming across multiple devices. Any suggestions for a modern router that will give better performance ? We have up to 10 devices hitting wifi. Thanks !
1 REPLY 1
Fixes: 399
Re: Router upgrade - recommendations ?
How many features do you want and how deep are your pockets?
If all you need is a bog standard combined modem/router with very good dual band wireless performance then go on to, for example, Ebay and spend around £30 on a BT Smarthub 6. You will find the easy setup instructions if you do a search on this board.
