Router update
- My Router
- Re: Router update
Router update
18-08-2020 2:55 PM
How can I update my router firmware?
I am on 1.645.516.0300936
Re: Router update
19-08-2020 7:51 AM - edited 19-08-2020 7:51 AM
What is the router model as the version number you quoted doesn't appear to be for currently supported Hub One and Hub Zero (2704n) models supplied by Plusnet?
https://www.plus.net/help/broadband/router-setup-guides/
Re: Router update
19-08-2020 8:48 AM
Software version 4.7.5.1.83.8.263
Re: Router update
19-08-2020 9:04 AM
Hi @BobMoore
Looks like you are on the latest update.
Plusnet Hub One | Software version 4.7.5.1.83.8.263 | Last update
Re: Router update
19-08-2020 9:15 AM
Re: Router update
19-08-2020 9:19 AM
As I said in my last post you have the latest update at this moment in time. If your router is registered with PN then I believe it will be automatically updated when and if a new version comes out..
Re: Router update
19-08-2020 9:19 AM
.263 from March 2019 is the current production version for the Hub One.
If you are suffering 5 GHz wifi failure issues, and wish to test the beta .273 release, you will have to post in this thread to request it
https://community.plus.net/t5/My-Router/Hub-One-5GHz-WiFi-issue/td-p/1696363/page/70
