Router stopped working
miketheb
Hi
My Hub One router stopped working for no apparent reason. It had been working fine for a couple of months. My computer was connected to the router, but there was no internet access
When I logged into the router I noticed that the user name had gone back to.......
setup@plusdsl.net
...so I changed it back to my real user name (I did also re-input my password) and the router worked fine again
What is odd is the router name (the one you can change if you wish) remained the same as I changed it to when I started with Plusnet.
So it looks like the router forgot the user name (it may have also lost the password, but did re-input it).
This is for information only - it may help you
Mike
2 REPLIES 2
Fixes: 1,466
Re: Router stopped working
Moderators Note
This topic has been moved from Fibre to My Router
miketheb
So the bottom line is...........
The SSID remained in the router memory which is why my computer would still connect to it.
I had changed the router ip addresses when I first set it up, and this also remained in the router memory,
The user named had been forgotten
As regards the password I don't know - it may or may not have been forgotten as I re-entered it
Regards
Mike
