Router so noisy
bexann
Router so noisy
I have just switched to plus net and the router is on my work desk.
Previous router was silent. This router sounds like an old pc when it's trying to access the hard drive!
Only when WiFi is being used tho but its driving me nuts as I have to sit by it all day!
I am hard wired but other people in the house sometimes work from home on WiFi and then it's so obvious.
I have read this could be caused by the 5ghz connection (which we've used with every provider and no such noise).
Is this a router fault? How do we sort it?
3 REPLIES 3
Fixes: 1,483
Re: Router so noisy
Moderators Note
This topic has been moved from ADSL Broadband to My Router
Fixes: 1,600
Re: Router so noisy
Thanks for your post @bexann and welcome to our Community Forums
I'm afraid that the fix for this would be to turn off the 5GHz wireless frequency by going into your router at 192.168.1.254
We've previously raised this issue with the manufacturer and we were advised that the noise is within tolerance
Fixes: 417
Re: Router so noisy
@bexann
In the past I have asked which specification with which it complies. Having received no reply one must assume it’s the general H&S level, which specifies the limit below which ear defenders are not required.
If you want a budget solution then buy a Smarthub 6 from an auction site, setting instructions are linked from here. https://community.plus.net/t5/My-Router/Using-A-BT-Smarthub-An-Update/m-p/1795292#M24601
Keep your hub one in case you need it for fault diagnosis.
