Router settings
andyshaw01
Router settings
Hi
I have two questions
Can anyone tell me if there is a way to disable or enable access to adult content?
Is there any reason why I couldn't watch TV through an internet connection - Now TV for example.  This was working until a few hours ago but now I cannot get access at all.  I wondered whether it might be due to the internet or broadband settings.
Many thanks
3 REPLIES 3
Gel
Aspiring Champion
Fixes: 27
Re: Router settings
bobpullen
Fixes: 288
Re: Router settings
What router are you using? If it's the Hub One that we provide, then I don't believe it has any in built parental control filtering, it does have access controls though.
We do have a network-based content filter that can be switched on/off/tweaked here.
Mav
Fixes: 507
Re: Router settings
Moderator's note:
As suggested above, thread moved to My Router.
Forum Moderator and Customer
