Router settings
- My Router
- Re: Router settings
Router settings
24-08-2017 11:16 PM
Hi
I have two questions
Can anyone tell me if there is a way to disable or enable access to adult content?
Is there any reason why I couldn't watch TV through an internet connection - Now TV for example. This was working until a few hours ago but now I cannot get access at all. I wondered whether it might be due to the internet or broadband settings.
Many thanks
Re: Router settings
25-08-2017 7:48 AM
Re: Router settings
25-08-2017 7:57 AM
What router are you using? If it's the Hub One that we provide, then I don't believe it has any in built parental control filtering, it does have access controls though.
We do have a network-based content filter that can be switched on/off/tweaked here.
Re: Router settings
25-08-2017 2:27 PM
Moderator's note:
As suggested above, thread moved to My Router.
Forum Moderator and Customer
