Router return?
BurntToast
Router return?
Does Plusnet require the return of the router on leaving?  I don't want to throw it away then get charged but it's old so not a lot of use I'd have thought.
4 REPLIES 4
Fixes: 387
Re: Router return?
@BurntToast Nope, PN  don't 'require' the return of the router on leaving, but as it is no good on other than the PN network, it is a good idea to return it, otherwise you have to dispose of it in accordance with the WEEE regulations.
I haven't looked (sorry) but I believe there is a returns procedure somewhere on the portal.
BurntToast
Re: Router return?
Thank you. I'll take a look.
Strat
Fixes: 565
Re: Router return?
@BurntToast
Have a look here https://www.royalmail.com/track-my-return/create/2886
BurntToast
Re: Router return?
Thank you.
