Router restart
FIXED- Subscribe to RSS Feed
- My Router
- Re: Router restart
26-05-2019 4:14 PM
Is it possible for someone to restart my router remotely, so that it will pick up my new static IP address?
Fixed! Go to the fix.
Re: Router restart
26-05-2019 7:29 PM
Moderator's Note(s)
Thread moved from ADSL Broadband to My Router.
Forum Moderator and Customer
Re: Router restart
26-05-2019 7:41 PM
You shouldn't need to get the router restarted remotely.
Assuming you have the Hub Zero (AKA 2704n) you can access your router's home page by entering 192.168.1.254 in your browsers address bar (you may need to enter your router's admin and password details which are on the back of the router. You can then select 'Disconnect' then 'Connect'.
If that hasn't done it you can restart the router by going to Advance Settings - System and click on Restart my Plusnet Hub.
Re: Router restart
26-05-2019 8:22 PM
My problem is that I'm currently not near the router and so I can't access it via it's local IP address. Are you able to PM me the current external IP?
Regards
Re: Router restart
27-05-2019 12:26 PM
Moderators are customers like you and I.
Can you get someone to switch the mains off and back on. This will reboot the router and do the job,
27-05-2019 1:14 PM
